Can't change printing page size
mentanto
Post by mentanto » Fri Nov 10, 2017 2:30 pm
Hi!
I have updated recently to new version and I can't change the paper size in the preview printer view.
Draw preferences->print->page. I change, for example, A4 ->A3 size and there is no effect.
Tentatively I can solve the problem opening an old .dxf file that is configured with the paper size that i want print. I delete all and copy all my new drawing.Then I can print with the size that I want.
Thanks!
My system is:
Versions
QCAD version: 3.19.0.0
Date: Nov 6 2017
Qt version: 5.5.1
Compiler version: gcc 5.4.0
Build Date: Nov 6 2017
Revision:
Architecture: x86_64
OS: Linux
OS version: Unknown
Locale
QCAD locale: es
Country: 197
Country name: España
Language: 111
Language name: español de España
Script: 7
Script name: Default
Decimal point: 44
Negative sign: 45
Positive sign: 43
Text direction: 0
System codec: UTF-8
Arguments: qcad,/home/maquinas/Documentos/Mejoras Laboratorio/Motor Paso a Paso/Motor Paso a Paso Caratula (copia).dxf
Plugins
Description=Import/export support for the DXF format. Based on dxflib.
FileName=/usr/lib/qcad/plugins/libqcaddxf.so
ID=DXF
License=GPLv2+
Name=DXF
QtVersion=5.5.1
URL=http://www.qcad.org
Version=3.19.0 (dxflib 3.17.0.0)
Environment
SHLVL=0
GDMSESSION=gnome-flashback-metacity
JOB=dbus
CLUTTER_IM_MODULE=
MANDATORY_PATH=/usr/share/gconf/gnome-flashback-metacity.mandatory.path
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
DESKTOP_SESSION=gnome-flashback-metacity
XDG_SESSION_ID=c1
XDG_GREETER_DATA_DIR=/var/lib/lightdm-data/maquinas
GTK2_MODULES=overlay-scrollbar
XDG_DATA_DIRS=/usr/share/gnome-flashback-metacity:/usr/local/share/:/usr/share/:/var/lib/snapd/desktop
DBUS_SESSION_BUS_ADDRESS=unix:abstract=/tmp/dbus-8CtUvo8qPO
XDG_RUNTIME_DIR=/run/user/1000
SESSIONTYPE=gnome-session
GTK_IM_MODULE=
XDG_SESSION_DESKTOP=gnome-flashback-metacity
XDG_CONFIG_DIRS=/etc/xdg/xdg-gnome-flashback-metacity:/usr/share/upstart/xdg:/etc/xdg
QT4_IM_MODULE=
XDG_SEAT=seat0
LOGNAME=maquinas
USER=maquinas
KICAD_PATH=/usr/share/kicad
LANG=es_ES.UTF-8
INSTANCE=
XDG_CURRENT_DESKTOP=GNOME-Flashback:Unity
XDG_MENU_PREFIX=gnome-flashback-
XAUTHORITY=/home/maquinas/.Xauthority
GNOME_KEYRING_PID=
SESSION_MANAGER=local/electricas:@/tmp/.ICE-unix/1457,unix/electricas:/tmp/.ICE-unix/1457
XDG_SESSION_TYPE=x11
QT_ACCESSIBILITY=1
QT_LINUX_ACCESSIBILITY_ALWAYS_ON=1
QT_QPA_PLATFORMTHEME=appmenu-qt5
GTK_MODULES=gail:atk-bridge:unity-gtk-module
DISPLAY=:0
GIO_LAUNCHED_DESKTOP_FILE_PID=22500
[email protected]=ibus
IM_CONFIG_PHASE=1
KIGITHUB=https://github.com/KiCad
GDM_LANG=es_ES
GNOME_DESKTOP_SESSION_ID=this-is-deprecated
GPG_AGENT_INFO=/home/maquinas/.gnupg/S.gpg-agent:0:1
HOME=/home/maquinas
SSH_AUTH_SOCK=/run/user/1000/keyring/ssh
UNICODEMAP_JP=cp932
XDG_VTNR=7
GIO_LAUNCHED_DESKTOP_FILE=/usr/share/applications/qcad.desktop
DEFAULTS_PATH=/usr/share/gconf/gnome-flashback-metacity.default.path
LANGUAGE=es_ES
PWD=/home/maquinas
SHELL=/bin/bash
UPSTART_SESSION=unix:abstract=/com/ubuntu/upstart-session/1000/1237
QT_IM_MODULE=ibus
XDG_SEAT_PATH=/org/freedesktop/DisplayManager/Seat0
XDG_SESSION_PATH=/org/freedesktop/DisplayManager/Session0
GNOME_KEYRING_CONTROL=
Re: Can't change printing page size
Post by Husky » Fri Nov 10, 2017 7:01 pm
Hi mentanto,
thanks! I checked it on Win10 and I have the same problem. Could you please file a bug report below
http://www.ribbonsoft.com/bugtracker/
Thank you.
Post by andrew » Fri Nov 10, 2017 7:06 pm
Bug report under:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1657
As a workaround you can use a layout block with a viewport (recommended in QCAD >= 3.19).
J-J
Moderator
Post by J-J » Fri Nov 10, 2017 7:10 pm
Hi guys,
Same behavior with Win 7
However if I do it within the viewport function the paper can be changed , but the status is not memorized when you try again in the main drawing e_confused
JJ
