[solved] Lineweight
slyde
[solved] Lineweight
Post by slyde » Fri Nov 24, 2017 8:03 pm
I can't increase lineweight and have it reflect on the drawing. When i set a new layer, it defaults to 0.25mm lineweight. So I increase it to 2.0mm, give it a name and a color and click OK. But I cant get thick lines when i use it. Can anyone tell me how to do this?
The first pic shows te new layer details.
Second pic shows a line drawn in Screen-based Linetypes
Last shows line in Draft Mode.
The lineweight stays the default 0.25mm. How can I make QCAD display a fat 2.00mm line?
Screenshot from 2017-11-24 13-01-43.png (201.59 KiB) Viewed 3518 times
Screenshot from 2017-11-24 13-02-07.png (180.6 KiB) Viewed 3518 times
Screenshot from 2017-11-24 13-02-20.png (181.65 KiB) Viewed 3518 times
Look! It's a bird. No! It's a plane! NO! It's QCAD hotkeys...faster than a possum falling out of a tree!!
OS: Linux Mint 18.3 Sylvia [64-bit]
QCAD Pro 3.19.2.0 [64-bit]
Re: Lineweight
Post by Husky » Fri Nov 24, 2017 8:44 pm
It is easier for us to help you with the drawing itself or at least an example drawing which shows the problematic too. Please attache the drawing to this post. Thanks.
slyde
Re: Lineweight
Post by slyde » Fri Nov 24, 2017 10:30 pm
I've tried every way I know to make the heavier lines appear thicker, but I just can't make that happen.
Screenshot from 2017-11-24 15-26-36.png (210.2 KiB) Viewed 3511 times
Screenshot from 2017-11-24 15-27-58.png (215.88 KiB) Viewed 3511 times
slyde
Re: Lineweight
Post by slyde » Fri Nov 24, 2017 10:34 pm
This is a block created with another CAD program. It's constructed using thick lines. I need to be able to do this in QCAD.
Screenshot from 2017-11-24 15-40-43.png (225.07 KiB) Viewed 3509 times
Re: Lineweight
Post by Husky » Fri Nov 24, 2017 11:53 pm
Husky wrote:It is easier for us to help you with the drawing itself or at least an example drawing which shows the problematic too. Please attache the drawing to this post. Thanks.
Please attache the dxf/dwg.
Re: Lineweight
Post by andrew » Sat Nov 25, 2017 12:33 am
This might be what you are looking for:
viewtopic.php?f=47&t=4534
If not, please do attach your DXF/DWG. It's really the only way we can see what's in that drawing.
slyde
Re: Lineweight
Post by slyde » Sat Nov 25, 2017 12:49 am
That's the ticket, Andrew. Thank you.
The problem was that I was using Lines instead of Polylines.
