NCP on eckert jantar 2
Kitnitti
Post by Kitnitti » Mon Feb 05, 2018 7:21 pm
Hey,
My company just purchased a Eckert Jantar 2 plasma cutting table and im looking for a good cad/cam software.
I tried out this one but couldnt save it in the right format (.ncp)
I really liked how easy and well arranged Qcad is and i would really like it to work.
If it doesnt work on our cutting table, do you have any other suggestions to what software we can use?
Thanks in advance
Kitnitti
Re: NCP on eckert jantar 2
Post by andrew » Mon Feb 05, 2018 7:26 pm
Thanks for your interest in QCAD/CAM.
QCAD/CAM can be configured to output virtually any output format through a postprocessor. If you know what kind of format your machine expects (example file, manual, etc), I can tell you more.
Please note that .ncp does not sufficiently define the format as this could be any dialect of G-Code or even something else entirely.
Kitnitti
Post by Kitnitti » Tue Feb 06, 2018 1:36 pm
Hei,
Do you know how i can find out which filetype it uses? Ive only seen .ncp format on the machine, and every instruction i can find is in polish.
And about postprocessor, which program can i use for that?
I am still abit new to this, and everything is
self-learned so far.
Thanks in advance
Kitnitti
Post by andrew » Tue Feb 06, 2018 1:37 pm
Do you have any example files, anything that is known to work with your machine at all?
Kitnitti
Post by Kitnitti » Tue Feb 06, 2018 1:47 pm
Im gonna check abit closer now, but i have only seen .ncp.
Kitnitti
Post by Kitnitti » Tue Feb 06, 2018 1:57 pm
All i can find is .ncp, on every example file and test file. On the machine itself
Kitnitti
Post by Kitnitti » Tue Feb 06, 2018 2:50 pm
Do i need a file to set the right file i need for qcad?
Post by andrew » Tue Feb 06, 2018 2:58 pm
You essentially need to know how such a file is structured. There are various formats in use for CNC processing. The most common one is G-Code which also exists in many variations. G-Code looks for example like this:
N10 G00 X5.0 Y4.0
N20 G00 Z2.0
N30 G01 Z-1.5
N40 X55 Y40
You could try to load and run a simple G-Code file (with save movements only!) and test it against your machine. This is a simple G-Code program that moves to X50:
N10 G01 X50
Copy/paste this into a file, name it test.ncp and try to run it with the appropriate caution.
Kitnitti
Post by Kitnitti » Tue Feb 06, 2018 3:08 pm
I found one place on an old machine a file
called .esi. I tried to open it on the machine and it works.
Im gonna try this thing you told me now too
Kitnitti
Post by Kitnitti » Tue Feb 13, 2018 2:59 pm
Can you just quick walk me through the
postprocessing on qcad?
Post by andrew » Mon Feb 19, 2018 10:36 am
Postprocessors are stored in directory "postprocessors" of your QCAD/CAM installation. These are JavaScript files which can be adjusted to do anything that can be done using a programming language. So it really depends a lot on the desired output format, what needs to be adjusted and how.
Kitnitti
Post by Kitnitti » Wed Feb 21, 2018 7:25 pm
ah okey
does this have any support for any hypertherm or plasma related things, like truehole and bevel cutting?
Post by andrew » Thu Feb 22, 2018 9:46 am
Kitnitti wrote:does this have any support for any hypertherm or plasma related things, like truehole and bevel cutting?
No.
