I have been using QCAD for months without any problem with Blocks. Today I must have Fat Fingered something that started it. Any of my drawings, old or new, now have the same error. Rebooting QCAD make no difference.
The Problem....
1 - I create a Block (See attachment 1).
2 - I now attempt to insert the block into the drawing and the block displays upside down Except for the text, as in Attachment 2.
3 - I then double click on the Block name in the list and it displays correctly fgor editing purposes which hints that the Block is not corrupted, only displaying incorrectly.
4 - Please Help!! Thanks.
Ken
I am using QCAD Pro 3.19.2.0 [64-bit] & W7 [64-bit].
[solved] Block Problems
- 1-2018-02-12 00_09_47-Plane Rack.dxf _ - QCAD.jpg (460.67 KiB) Viewed 3254 times
- 2-2018-02-12 00_13_16-Plane Rack.dxf _ - QCAD.jpg (465.78 KiB) Viewed 3254 times
- 3-2018-02-12 00_14_57-Plane Rack.dxf _ - QCAD.jpg (458.49 KiB) Viewed 3254 times
Re: Block Problems
Hi Ken
If the option bar doesn't pops up please activate this feature below Menu / View / Toolbars and Widgets / Toolbars / Options
Keep an eye on the option bar which pops up when you insert a block.kenterm wrote:2 - I now attempt to insert the block into the drawing and the block displays upside down Except for the text, as in Attachment 2.
Re: Block Problems
Thanks Husky - I knew I did something but had no idea what. We learn every day. Thanks!
