[solved] Dimension lines at wrong position
yeti01
Post by yeti01 » Sat Mar 24, 2018 12:04 pm
If you open a file (in QCAD Professional Edition) that was created by the Community Edition, some dimension lines might be shown at a different position. This seems to happen if you have edited the Text Position.
In the example below I created an Aligned Dimension of length=20 (Community Edition). The text original position was at Y=11.875. If I open this file in the Professional Edition everything is fine.
Back to the Community Edition, I changed the Text Position from Y=11.875 to Y=12.
Screen Shot 2018-03-24 at 11.41.03.png (48.53 KiB) Viewed 4522 times
If I open this changed file in the Professional Edition again, the Dimension Line is also shown at Y=12 (before it was Y=10).
Screen Shot 2018-03-24 at 11.43.16.png (45.06 KiB) Viewed 4522 times
Re: Dimension lines at wrong position
Post by Husky » Sat Mar 24, 2018 5:34 pm
Hi yeti01 - welcome to the QCAD Forum.
You can reset the dimension label position below Menu / Dimension / Reset Label Position. Just selected the dim and launch this tool ...
yeti01
Post by yeti01 » Sun Mar 25, 2018 12:53 pm
Hi Husky, thanks for the welcome and for your answer.
In fact I didn't know this feature but unfortunately it doesn't solve the problem.
In the example above, the Professional Edition shows the dimension line at Y=12 whereas the Community Edition shows it at Y=10 (please keep in mind it is the same DXF-R15 file). For me it looks like both Editions interpret the DXF-R15 format in a different way. Do you use the same dxflib for both?
Post by andrew » Fri Apr 06, 2018 12:09 pm
yeti01
Post by yeti01 » Mon Apr 16, 2018 6:25 pm
Problem solved. Thanks Andrew!
