Block Dimensions Not Scaling In Layout Space Viewport
mbhochha
Post by mbhochha » Mon Mar 26, 2018 9:27 pm
When I create a viewport to my model space which includes blocks with dimensions, the block dimensions do not scale properly. If I explode the blocks the dimensions scale properly. And dimensions which are not part of a block scale properly.
Windows 7 Pro
QCad 3.19.2
Bolt Hole Locations.dwg
(22.68 KiB) Downloaded 129 times
Re: Block Dimensions Not Scaling In Layout Space Viewport
Post by andrew » Mon Mar 26, 2018 11:43 pm
