[solved] Pinting : white on an colored rectangle
Farmill
Post by Farmill » Wed Apr 11, 2018 2:17 pm
I have drawing with a layer which contains a filled rectangle (in this case blue).
I have some text and other objects like circles colored white on top of the rectangle colored. This looks as expected on screen. However as I use print (or print preview) the blue remains blue but the text/circles color becomes black. If I use any other color as it will remain that color when printed. So yellow text/circles on an blue rectangle stays yellow. It looks like white (and grays) are turned into black.
I’m using version 3.19.2
Can someone tell me what I’m doing something wrong here?
Re: Pinting : white on an colored rectangle
Post by andrew » Wed Apr 11, 2018 2:20 pm
You might have to switch off auto color correction. Please refer to the last post / last paragraph at:
viewtopic.php?f=47&t=2611#p19406
Farmill
Post by Farmill » Wed Apr 11, 2018 6:18 pm
Your answer solved my problem, thank you very much. :D
