Crash Importing
Jam35
Crash Importing
Post by Jam35 » Thu Jul 05, 2018 12:30 pm
Versions
QCAD version: 3.21.1.0
Date: Jun 29 2018
Qt version: 5.5.1
Compiler version: MSVC++ 12.0 (2013)
Build Date: Jun 29 2018
Revision: f91002a58ed31c64923d575ac043c1672a192bb0
Architecture: x86_64
OS: Windows
OS version: Windows 7, Windows Server 2008 R2 (operating system version 6.1)
Hi.
The attached .dxf crashes QC on import.
It opens fine but I cannot import it on top of another drawing.
Any ideas? Thanks.
Faulting application name: qcad.exe, version: 3.21.1.0, time stamp: 0x5b3563ab
Faulting module name: MSVCR120.dll, version: 12.0.21005.1, time stamp: 0x524f83ff
Exception code: 0xc0000005
Fault offset: 0x000000000003c3f9
Faulting process id: 0x1c14
Faulting application start time: 0x01d4144cbd865801
Faulting application path: C:\Program Files\QCAD\qcad.exe
Faulting module path: C:\Program Files\QCAD\MSVCR120.dll
Report Id: 32ae50d7-8040-11e8-b525-901b0e3b9d7a
ABC.dxf
(106.34 KiB) Downloaded 377 times
Re: Crash Importing
Post by andrew » Thu Jul 05, 2018 2:03 pm
Thanks for your report.
The problem seems to be caused by a missing image file (logo.png) referenced by the block "A4 Layout"
As a workaround, you can either delete the image or provide an image file "logo.png" in the same folder as your drawing file.
To delete the image file:
- open ABC.dxf
- View > Block List
- Double-click block "A4 Layout"
- View > Selection Filter
- Entity type: "Image"
- Click the button at the bottom left of the selection filter widget to select all images
- Hit Delete
The crash will be fixed for the next release.
Jam35
Re: Crash Importing
Post by Jam35 » Fri Jul 06, 2018 10:04 am
Works great, thank you.
