Cannot use custom fonts with -autostart script
Ewald Moitzi
Post by Ewald Moitzi » Tue Jul 10, 2018 11:12 am
Hello forum,
I'm using QCAD Professional 3.18.1, both on Ubuntu 18.04 and Debian Jessie inside a Docker container. The problem that I have occurs in both environments.
I'm trying to add a text entity to a .dxf with a script called from the command line. I use additional true-type fonts, but they are always replaced with the standard font. According to the QCAD gui the fonts are available, but when I list the fonts with
RFontList.init();
print (RFontList.getNames());
(Is this the right way to check installed fonts?)
they do not show up. The code used to create the Entity:
function addText(doc, text, size, font, offsetx, offsety, bold, italic, hAlign) {
    if (isNull(font)) font = "Standard";
    if (isNull(hAlign)) hAlign = CONSTANTS[align];
    if (isNull(bold)) bold = false;
    if (isNull(italic)) italic = false;
    var height = parseInt(size);
    var angle = 0.0;
    var vAlign = RS.VAlignTop;
    var position = new RVector(offsetx, offsety);
    var entity = new RTextEntity(
        doc,
        new RTextData(
            position,
            position,
            height,
            100.0,
            vAlign,
            hAlign,
            RS.LeftToRight,
            RS.Exact,
            1.0,
            '\\H' + size + ';' + text,
            'Sansation',
            bold,
            italic,
            deg2rad(angle),
            false
    var di = new RDocumentInterface(doc);
    di.applyOperation(new RAddObjectOperation(entity, false));
The fonts are installed in /usr/share/fonts, and are listed when calling 'fc-list'.
Thanks,
Ewald
Re: Cannot use custom fonts with -autostart script
Post by andrew » Tue Jul 10, 2018 11:22 am
You might have to set the environment variable
QT_QPA_FONTDIR=/usr/share/fonts
If you cannot fix the problem, please provide more information:
- What are the exact arguments passed to QCAD to run the script?
- Which QCAD package are you using (file name of installer)?
Ewald Moitzi
Post by Ewald Moitzi » Tue Jul 10, 2018 12:42 pm
Hi Andrew,
thanks for the quick answer. Setting the environment variable did not help unfortunately.
qcad package: qcad-3.18.1-pro-linux-x86_64.run
The script is called with:
qcad -platform offscreen -allow-multiple-instances -no-gui -autostart qcad.js test.dxf
(I created a simplified script file removing all the custom parameters with hardcoded params for the text)
One more thing: When opening the file the font set for the text is 'standard'.
Ewald
Post by andrew » Tue Jul 10, 2018 1:58 pm
Can you attach the generated test.dxf output file?
Ewald Moitzi
Post by Ewald Moitzi » Tue Jul 10, 2018 2:04 pm
Sure. I have also attached the script itself.
test_merged.dxf
(7.45 MiB) Downloaded 323 times
qcad.js
(2.11 KiB) Downloaded 341 times
Post by andrew » Tue Jul 10, 2018 2:12 pm
The script is exporting to DXF R12 which does not support TrueType fonts. Try using a newer DXF version such as R27.
Ewald Moitzi
Post by Ewald Moitzi » Tue Jul 10, 2018 2:32 pm
Ah, I see.
I will try that, thanks!
Kind Regards,
Ewald
