qcad doesn't print, everything else does
dobo
Post by dobo » Thu Jul 19, 2018 2:07 am
So it's not a printer issue. Running print on a qcad file, printer runs, paper goes thru, no ink. Other than qcad, everything prints fine.
dobo
Re: qcad doesn't print, everything else does
Post by dobo » Thu Jul 19, 2018 3:26 am
op system mac os sierra 10.12.6
qcad pro 3.19.2
In the past all qcad files printed fine, so I'm thinking a software switch somewere acidentally went to white. just a guess. Peter
Post by Husky » Thu Jul 19, 2018 6:39 am
Yup - sounds like a setting issue. Please doublecheck your settings based on this tutorial:
https://qcad.org/en/tutorial-printing
If the issue persist please attach the drawing or at least an example drawing what shows the same issue. Thanks.
