Info - Polyline Area (dont measure)
Hi!
Im using qcad 3.21.2
Im trying to calculate polyline area (previous version work),
but dont show.
Info - Polygonal Area works but i have to "redraw" the polyline
http://prntscr.com/kfc3w2
Thanks for your work!
but dont show.
Re: Info - Polyline Area (dont measure)
please attach an example drawing which shows this effect. Thanks.
BTW: The Property Manager will give you also that information.
Thanks Husky , but, property editor dont give me area also.
Now using 3.21.3 version
https://prnt.sc/kya075
Please attach the drawing (or just an example) which shows this issue. Thanks.
hi, im cant measure area, from info - polyline or property editor.
send 2 images and a drawing file example,
property editor show : Closed : "no". (but seems closed)
In others pc,s this example works (give area), so it's a problem with mi installation
(remove, clean registry, remove all qcad's file, reinstall many times).
Any help
https://drive.google.com/open?id=1HacTg ... uWdGrGjdwd
https://drive.google.com/open?id=1C6wBj ... I0tAupqpYh
https://drive.google.com/open?id=1dwi4a ... 7Qei3CG3LL
qcad ver: 64bits 3.22.0
OS: Windows 10 64 b.
default installation procedure
Thanks!
Gaston
Any help
Thanks!
Gaston
Hi gastonbravo,
weird, after loading your dxf, I get 170 units, both in the property editor and with polygonal area. Running latest QCAD on win 7-64
JJ Win7 pro-64
Hi J-J, thanks, that's right, in other pc s works fine
(and in my notebook, works 6 month before) i used a lot.
So it's an issue in my particular installation (no general problem).
Thanks anyway
Saludos desde Chile
Gaston
Thanks anyway
Saludos desde Chile
Gaston
I'd recommend to try resetting your QCAD configuration. Optionally, you might want to backup your old QCAD3.ini file first and then post it here if that turns out to be the problem, so we can look into what caused the problem.
- Registered Member
I seem to be having the same issue. QCAD populates
Version 3.27.1.0 Community Edition
It is happening on two platforms, Toughbook w/ Windows 10 Pro
Desktop with Windows 10 Pro.
I've attached a super simple example. I get Total length, no Area. Polyline Area command gives same results
Help? Thanks!!! I need this command!
Followed above suggestion to no avail. Attaching ini file
- QCAD3.ini
- (105.7 KiB) Downloaded 265 times
- PolylineTest Screencap.png (102.76 KiB) Viewed 5190 times
I can confirm that this only gets calculated in QCAD Professional. These properties and tools will be removed from QCAD CE in the next release.
For polylines without arc segments, you could use Info > Polygonal Area instead.
- Registered Member
Thank you Andrew. I looked for verification of it not being included in CE but couldn't find it.
I will use the other tool. It works!!
Thank you.
Thank you.
