Hi.
Am using
Version: 3.21.2.0 (3.21.2) in Windows 10 Pro.
I have created library items from an AutoCad file.
When I use these items on a new drawing, I get random corruptions of the placed item - in this example, I placed the PC item first then the PLC item which was corrupted.
Attachment T3 is as it should be.
Attachment T4 shows the corruption.
Libraries attached.
Andy
[solved] Library items random corruption on placement
- t4.jpg (100.7 KiB) Viewed 3377 times
- t4.dxf
- (211.45 KiB) Downloaded 322 times
- t3.jpg (99.7 KiB) Viewed 3377 times
- t3.dxf
- (205.14 KiB) Downloaded 325 times
- QCAD_Libraries.zip
- (314.11 KiB) Downloaded 320 times
Re: Library items random corruption on placement
the Blockname *U0 is used twice for different items (Rectangle and PC).
If you insert a Library Item witch contains the same block name but different contend and the option is chosen to overwrite Blocks then the already inserted Blocks (Rectangle) are replaced by the new Block (PC).
In this case 10 rectangle are replaced by 10 PC's.
Many thanks.
