Hi I,m using Windows 10 with Qcad Professional 3.21.2
I have an issue with the Options toolbar, which I do not had before.
When I switch off the options toolbar via Right mouse click Toolbars - Options, the optons toolbar goes away.
However every time when I select a command from one of the toolbars or open a file, the Toolbar - Option is activated again.
This behavior is anoying, because the option Toolbar uses a lot of space on the active screen, due to the square on the left see attached picture.
How can I hide the option toolbar constantly.
Thanks in advance.
[solved] Options Toolbar keeps appearing even when switched off
- OptionToolbar001.jpg (43.34 KiB) Viewed 4731 times
Re: Options Toolbar keeps appearing even when switched off
I can't see an Option-bar on your screenshot. If you meant the big symbol on the left side with the Mouse Pointer that is an "Active Tool" indicator.
However - the size of that symbol is way to big.
1. Did you changed the Icon Size below Application Preferences?
2. Did you mixed multiple QCAD Versions in the same directory?
I just started Qcad and did not changed anything.
How to change the size of this big symbol, 'active tool' indicator.
The option toolbar keeps on coming back, even when I switch it off.
Other toolbars like view, edit, snap, are not coming back.
So what can I do?
So what can I do?
I uninstalled Qcad en then installed Qcad again.
Problem persists!
What to do?
Problem persists!
What to do?
Ok, then try a QCAD reset. Rename the qcad3.ini or if you prefer to delete it go ahead but don't empty the recycle bin - just in case.
Instructions how to reset QCAD can be find here:
Keep us posted.
Keep us posted.
Thanks!!!
Problem solved.
Problem solved.
