hatching doesnt work
ricco64
Post by ricco64 » Tue Aug 28, 2018 5:49 pm
Hi ,im about to explode .cant get hatching to work.solid fill does though??
I keep getting closed loop errors(even though I purposely draw circles to prove my point to myself
version 3212 on windows 10
Re: hatching doesnt work
Post by Husky » Tue Aug 28, 2018 7:12 pm
I deleted the second identical posting of you. Please post only once to each issue/question. Thanks.
To help you effective with this issue we need to see the drawing or at least an example drawing which shows the same issue. Please attache a drawing with description which contour failed regarding the hatch tool. Thanks.
ricco64
Post by ricco64 » Tue Aug 28, 2018 7:24 pm
I can’t even hatch a circle ,a square anything.
It goes through the motions but loop error often comes up. Bizarrely solid fill works
Post by andrew » Tue Aug 28, 2018 10:05 pm
Can you please attach the DXF file after applying the hatch? It's quite possible that the hatch was created but is not visible due to the pattern scale being off, there might be invalid drawing preferences, etc.
