Block fractures when Scaled
BarryW
Post by BarryW » Thu Oct 04, 2018 4:10 pm
Windows 10, i7 Processor, QCad pro 3.21.3.0
Afternoon all,
The attached drawing contains one block, of a simple railway turnout.
If I select the block and then, on the property pallete, change the 'Y' scale to 0.9,
the block fractures rather than scales. Can anyone else verify this ?
Andrew - is this a bug ?
thanks,
Barry.
Block_Test1.DXF
(116.01 KiB) Downloaded 36 times
Re: Block fractures when Scaled
Post by andrew » Thu Oct 04, 2018 9:03 pm
Non-uniform scaling of blocks is currently only supported for blocks containing exclusively lines or points. This is a known limitation.
BarryW
Post by BarryW » Thu Oct 04, 2018 9:16 pm
OK, Thanks for that info,
Barry.
