Hello all,
I'm recently using last QCAD 3.21.3.0 version. I realized text with simple text option enabled is not rotating like before, as far as I remember. Now it rotates always with its reference point as rotating point, even when it is part of a block or a group of selected entities.
Is that some kind of bug or it's going to be like this so on?
Thank you! Best regards,
David
Simple text rotating
Re: Simple text rotating
I cannot reproduce this here.
- indicate the operating system you are using and the version thereof
- attach original drawing files (DXF, DWG, ...) if appropriate
- include screenshots if appropriate
Please be as specific as possible in describing your problem, so we can help you efficiently, thanks.
- dfriasb
- Senior Member
Hi again,
Here you can find the attached dxf file. I'm running QCAD 3.21.3.0 on Linux Ubuntu 18.04.
You can test selecting all entities and rotating (F5 or F6 for example). In my case some texts are not rotating properly.
Thanks,
David
Thanks,
David
- text_weird_rotation.dxf
- (428.34 KiB) Downloaded 400 times
Here's how that file looks here after loading with QCAD 3.21.3:
After selecting all and pressing F6:
Is this the same for you? If so, that's expected behaviour.- dfriasb
- Senior Member
It only happened once with only one drawing. If I see any other strange thing I'll advice.
Thank you!
Thank you!
