Line length and dimensions are wildly different
kplumb
Post by kplumb » Sat Dec 01, 2018 9:54 pm
Sorry for the silly question as I'm new to QCad.
I've setup a document in inches and the dimensions as architectural.
I drew a line 21' long. The length displays properly in the display from 0,0 to 21'-0". Then added a dimension to test dimensioning. The dimension shows the line to be 105'-0" long.
Lines of different lengths are also wildly off. I'm sure I've setup something incorrectly. Suggestions?
Re: Line length and dimensions are wildly different
Post by Husky » Sat Dec 01, 2018 11:37 pm
Hi kplumb - welcome to the QCAD Forum.
Your drawing Unit is inch - your line is 21' what means 252". Where can you seen this "length display" from 0,0 to 21'-0"? Ruler?
Note: When you launch the Dim tools an option bar pops up with the possibility to use a scale. Make sure it is set to 1:1.
If that doesn't solves the issue please attach the drawing to this post. Thanks
