Can't change application preferences
hans
Post by hans » Wed Jan 02, 2019 11:22 pm
Hello
I'm using qcad pro 3.21.3.0 (3.21.3) on linux (Ubuntu 18.04)
recently i noticed that I can't change the application preferences any more. No changes that I try (another language, autosave etc.. ) have any effect.
What did I miss? Did anyone experience the same issue?
with friendly regards, Hans
Re: Can't change application preferences
Post by andrew » Thu Jan 03, 2019 11:41 am
Please check the permissions of the ~/.config/QCAD folder and files.
Alternatively, reset the QCAD configuration:
hans
Post by hans » Thu Jan 03, 2019 12:21 pm
Hello Andrew,
the permission were indeed changed to root, no idea how that happened.
Thanks a lot, the problem is solved!
