Hello all,
I cannot see some entities in a viewport. They are in the model, but not showed in the L(*Paper_Space16) block viewport.
I'm using QCAD Professional 3.21.3.0 (3.21.3) Version in Ubuntu OS.
Here I attach the file and screenshots. Any help will be very appreciated. Best regards,
David
Viewport missing some entities
- dfriasb
- Senior Member
- casa spania.2013.explodat -- proves 2 - pàg 6.dwg
- (86.2 KiB) Downloaded 400 times
- Screenshot from 2019-02-11 17-41-02.png (205.03 KiB) Viewed 3222 times
- Screenshot from 2019-02-11 17-41-23.png (200.66 KiB) Viewed 3222 times
- Screenshot from 2019-02-11 17-49-02.png (93.77 KiB) Viewed 3222 times
Re: Viewport missing some entities
1. Make sure that the property editor show Z coordinates:
Edit > Application Preferences > Widgets > Property Editor > Display Z Coordinates
2. Set the Z coordinate of the "View Target" property of the viewport to 0:
- select the viewport
- in the property editor set "View Target > Z" to "0":
- dfriasb
- Senior Member
Yes! That's working! Thanks a lot Andrew!
