[solved] Linetype issue
Nate
Post by Nate » Fri Feb 22, 2019 1:58 pm
It is a small issue but very annoying when i click on a line it appears to be a dotted line attached is a dxf
Test.dxf
(99.77 KiB) Downloaded 124 times
Re: Linetype issue
Post by Clive » Fri Feb 22, 2019 2:40 pm
Hello Nate, welcome.
Most likely the line type is set to something dashed!
Best practice is to set up your own layers and set the line weight, line type and colour to what works for you!
Nate
Re: Linetype issue
Post by Nate » Fri Feb 22, 2019 2:59 pm
i had made sure it is set to continuous i have a feeling it has something to do with the application preferences menu ????
Re: Linetype issue
Post by Husky » Fri Feb 22, 2019 9:40 pm
... i have a feeling it has something to do with the application preferences menu ????
Hi - I assume you are right :wink:
The dxf shows nothing unusual to me - please post a screenshot with a selected entity like this one. Thanks.
Nate
Re: Linetype issue
Post by Nate » Mon Feb 25, 2019 1:44 pm
this is a screenshot
Nate
Re: Linetype issue
Post by Nate » Mon Feb 25, 2019 1:49 pm
any help how to fix this??
Re: Linetype issue
Post by andrew » Mon Feb 25, 2019 3:27 pm
Looks like a secondary selection color is enabled under:
Edit > Application Preferences > Graphics View > Colors > Use secondary selection color
Nate
Re: Linetype issue
Post by Nate » Mon Feb 25, 2019 4:11 pm
Perfect Thank you Very much
