[solved] Linetype issue
Posted: Fri Feb 22, 2019 1:58 pm
by Nate
It is a small issue but very annoying when i click on a line it appears to be a dotted line attached is a dxf
Re: Linetype issue
Posted: Fri Feb 22, 2019 2:40 pm
by Clive
Hello Nate, welcome.
Most likely the line type is set to something dashed!
- 1.jpg (35.24 KiB) Viewed 10696 times
Best practice is to set up your own layers and set the line weight, line type and colour to what works for you!
- 2.jpg (41.45 KiB) Viewed 10696 times
Re: Linetype issue
Posted: Fri Feb 22, 2019 2:59 pm
by Nate
i had made sure it is set to continuous i have a feeling it has something to do with the application preferences menu ????
Re: Linetype issue
Posted: Fri Feb 22, 2019 9:40 pm
Nate wrote: ↑Fri Feb 22, 2019 2:59 pm
... i have a feeling it has something to do with the application preferences menu ????
Hi - I assume you are right
The dxf shows nothing unusual to me - please post a screenshot with a selected entity like this one. Thanks.
- Husky-2019.02.22-01.png (2.33 KiB) Viewed 10677 times
Re: Linetype issue
Posted: Mon Feb 25, 2019 1:44 pm
by Nate
this is a screenshot
Re: Linetype issue
Posted: Mon Feb 25, 2019 1:49 pm
by Nate
any help how to fix this??
Re: Linetype issue
Posted: Mon Feb 25, 2019 3:27 pm
Looks like a secondary selection color is enabled under:
Edit > Application Preferences > Graphics View > Colors > Use secondary selection color
Re: Linetype issue
Posted: Mon Feb 25, 2019 4:11 pm
by Nate
Perfect Thank you Very much
