Ver. 3.22.0.0 for MacOS (latest).
I've tried to print some drawing today and meet unusual trouble. When I press printer icon in Preview QCAD immediately crashes.
It was necessary to export several views to PDF and then print them via standard MacOS tool. It is not very soon and convenient...
Checked for updates (no), clean the system by CleanMyMac3 and even rebooted macbook. Nothing helps.
ps: It is possible that problem is not new since I do not print on paper often.
[solved] QCAD doesn't print
Re: QCAD doesn't print
Please attach your drawing and indicate your macOS version and the installed package (file name of downloaded DMG file), thanks.
MacOS Mojave 10.14.4
QCAD Pro is latest version (DMG file I deleted two months ago...).
- 1 этаж.dxf
- (1.27 MiB) Downloaded 445 times
Thanks. The file loads, shows and prints fine here (macOS Mojave, QCAD 3.22.0.0). Please double-check that you have downloaded the correct DMG for your system (qcad-3.22.0-pro-macos-10.14.dmg).
If you cannot solve the problem, please indicate exactly how you proceed, for example:
1. Open QCAD
2. Load DXF file
3. File > Print Preview
4. ...
1. Open QCAD
2. Load DXF file
4. ...
Hmm. Just downloaded another DMG from my 'personal page' and reinstalled QCAD.
Now it works properly.
The only difference which I see is
Revision: 2ba5a26380d25bb1699c95a808edb01c083385a1 (older one).
Now is 2ba5a26
Anyway it fully satisfies me
Many thanks for your prompt help!
Now is 2ba5a26
