[Mac]dwg2pdf Qcad Crash And "Segmentation fault: 11" Error.
Posted: Fri May 17, 2019 10:37 am
Hello.
When I used dwg2pdf, I confirmed the following problem
・Command
・Terminal
According to the examination, it is generated when “±” is used in SJIS DXF file, and R21 or higher DXF format.
It did not occur in UTF-8.But, UTF-8 can not be used because it is garbled...
I have attached the file in question.Please confirm.
Thank you.
・Command
/Applications/QCAD-Pro.app/Contents/Resources/dwg2pdf -l -a -n -fs standard Arial -paper=A3 -outfile=out.pdf sample.dxf.sjis.dxfCode: Select all
18:32:10: Debug: RDwgPlugin::init
18:32:10: Debug: RDxfPlugin::init
18:32:10: Debug: RHelpPlugin::init
18:32:10: Debug: RPolygonPlugin::init
18:32:10: Debug: RProScriptsPlugin::init
18:32:10: Debug: RScriptsPlugin::init
18:32:10: Debug: RSpatialIndexProPlugin::init
18:32:10: Debug: RTriangulationPlugin::init
18:32:10: Debug: calling odInitialize
18:32:10: Debug: dropped global XDATA (no res buf): "ViewportCenter"
/Applications/QCAD-Pro.app/Contents/Resources/qcad: line 18: 32033 Segmentation fault: 11 DYLD_LIBRARY_PATH="$DIR" "$binary" "$@"According to the examination, it is generated when “±” is used in SJIS DXF file, and R21 or higher DXF format.
Thank you.
