Problem opening DWG files in QCAD.
FergusB
Post by FergusB » Mon Aug 12, 2019 1:28 am
OSX v10.14.6
QCAD Pro v3.23.0.0
I am a new user of QCAD Pro and am having some difficulty opening some DWG files which I thought were fairly simple drawings. The file appears to open OK and the layer list is presented but there is no drawing shown. This only happens in the case of a few files - most DWG files open OK. I'm attaching a problem file and would appreciate any assistance on this. Thanks!
#394 Radio Battery Distribution.dwg
(90.21 KiB) Downloaded 23 times
Senior Member
Re: Problem opening DWG files in QCAD.
Post by CVH » Mon Aug 12, 2019 3:29 am
Your drawings details seems to sit inside blocks.
Qcad uses blocks as groups.
In the Model space there aren't any block refs so nothing shows.
In Layoutspace I see an A3 landscape with drawing entities.
And these are all part of the different layers.
This confuses me too.
Post by Husky » Mon Aug 12, 2019 5:27 am
Hi FergusB - welcome to the QCAD forum,
QCAD expects dxf/dwg drawings based on the standard - this example drawing has nothing to do with a "standard" drawing. I can't say what messed this drawing up (an other CAD program, a dwg converter etc.) but it is difficult for QCAD to handle it.
1. the drawing should be on Model_Space but it is on Paper_Space
2. Blocks are not really blocks, it looks like a "puzzle" of entities ...
3. I have no proof but I've the feeling 3D played also a role ...
Howsoever - it is partly fixable. Open the edit mode for the paper_space, select everything and cut it into the clipboard. Make the Model_Space active and insert the content of the clipboard into the model_space. Save the drawing after every successful step - this drawing could crash QCAD. Next, try just in case, to flatten the drawing to 2D: Menu/Misc/Modify/Flatten Drawing to 2d. Then purge all unused layers and blocks: Menu/Modify/Purge unused layers and blocks.
The result should be something like this:
(29.41 KiB) Downloaded 21 times
Addition note: Avoid file names with special characters like # (#394 Radio Battery Distribution.dwg). A few Operation systems have still problems with that :wink:
FergusB
Post by FergusB » Mon Aug 12, 2019 12:24 pm
Many thanks for the help. As these are fairly simple drawings, I can work with your fix. As they are 15 years old, it is quite possible that they may have been corrupted by another application over the years. Thanks again.
