copy and paste
JensA
copy and paste
Post by JensA » Tue Aug 20, 2019 1:44 pm
Hi everybody,
since updating to version 3.23.0 (windows 32bit) copy and paste seems to work no more.
As usual, I select an element, choose copy from the context menu (or press ctrl c), switch to an other tab with different drawing.
Now, when I choose paste from the context menu (or press ctrl v) only an empty frame appears.
Does anybody have an idea?
Re: copy and paste
Post by Husky » Tue Aug 20, 2019 5:26 pm
Hi everybody,
Is this "empty frame" still empty after inserting it into the drawing?
Re: copy and paste
Post by CVH » Wed Aug 21, 2019 8:09 am
Paste to current and current is locked?
JensA
Re: copy and paste
Post by JensA » Wed Aug 21, 2019 10:08 am
The "empty frame" appears at the lower left edge of the drawing and cannot be moved or inserted into the drawing. There is no content in it.
The frame disappeares after clicking the right mouse button.
I have installed the version 3.22 again, and everything works fine.
Does anybody have the same problem?
