Hints.
Longines
Hints.
Post by Longines » Fri Feb 14, 2020 6:30 pm
Hello.
After reinstalling the program I lost hints of the function during drawing, namely: perpendicular, intersections, etc. How to restore it ?.
Best regards, Longines
Re: Hints.
Post by Husky » Fri Feb 14, 2020 10:23 pm
Hello.
After reinstalling the program I lost hints of the function during drawing,...
Was the reinstalling done in an already existing QCAD installation? If yes please deinstall QCAD and reinstall it in a new or at least empty subdirectory.
Longines
Re: Hints.
Post by Longines » Sat Feb 15, 2020 9:10 am
Installation made after uninstalling the program. I even deleted entries in the registry. I think it's a matter of Snap settings, but everything is marked there. Let me remind you that earlier when drawing a line to another part of the drawing, a cursor (hint) appeared at the mouse cursor. Now this hint is gone.
Re: Hints.
Post by andrew » Tue Feb 25, 2020 1:25 pm
You can reset your QCAD as described here:
Longines
Re: Hints.
Post by Longines » Fri Feb 28, 2020 8:39 pm
Hello Andrew
Thank you very much for the advice. After deleting the Qcad3 file and restarting, everything got back to normal. This file was hidden so I didn't have a chance to find it on disk.
Best wishes - Chris
