Laggy interface on macOS
BobRockefeller
Post by BobRockefeller » Wed Feb 19, 2020 7:48 pm
I'm running macOS 10.15.3 and QCAD-Pro 3.24.2 on a iMac Pro (3.2 GHz 8-Core Xeon W, 32 GB RAM 2666 MHz DDR4 RAM, Radeon Pro Vega 56 8 GB video card).
Many QCAD operations are laggy. Selecting an element, for example, highlights the element in gray, pauses, unhighlights the element, pauses, highlights the element with its 'handles' and updates the Properties dialog. Clicking where no elements exist deselects all after a similar flash and pause of highlighting.
Drawing a two-point line is slow, too. The second point lags far behind the mouse as it moves. After clicking the second point in place, there is another pause before the tool continues for extending that line with another.
Do I have a setting out of place somewhere? Is they a way to get QCAD speedy?
Bob
Bob Rockefeller
Midway, GA, USA
Re: Laggy interface on macOS
Post by CVH » Wed Feb 19, 2020 9:36 pm
Qcad might get slower with huge and complex drawings.
But then we talk of really big files with lots and lots of blocks, splines or complex hatches in it.
Other examples can be 3th party dxf files.
Or faulty dxf/dwg files.
For that we need the examine the file itself.
If you have the explained behaviour in a new drawing then there is something not right.
QCADpro 3.24.3.0 / win7pro 32 bit / 4GB / 1e generation i7 2.6Ghz / HDD GeForce GT 520
BobRockefeller
Post by BobRockefeller » Wed Feb 19, 2020 9:49 pm
It's not a complex file and it is a new drawing. Where should I be looking for a poor preference choice or some other configuration problem?
Bob
Bob Rockefeller
Midway, GA, USA
Post by CVH » Wed Feb 19, 2020 11:43 pm
With a new drawing I meant one started in Qcad from zero.
You quoted back the '3th party' too.
Do you mean it is a new dxf/dwg from a 3th party?
The most recents post about lag are about:
Correct installation.
Blocks, Blocks in Blocks.
Splines or very short beziers-strings.
Many or very complex hatches.
Start by the first.
Do a clean and correct install.
This did solved it for so many.
BobRockefeller
Post by BobRockefeller » Thu Feb 20, 2020 12:06 am
Start by the first.
Are there any notes or suggestions for ensuring a "clean install?"
I have a file that started and a DXF export from another app and then was greatly redrawn in QCAD. But a freshly created new QCAD file shows the same lag.
I have no blocks, splines, bezier-strings, nor hatches. It's a very simple line and arc drawing.
Bob
Bob Rockefeller
Midway, GA, USA
Post by Husky » Thu Feb 20, 2020 8:27 am
Hi, I recomment to follow the installation tutorial by the letter and it should work like a charm.
https://qcad.org/en/documentation/insta ... nder_macOS
One side note - never mix different QCAD versione in the same subdirectory. :wink:
BobRockefeller
Post by BobRockefeller » Thu Feb 20, 2020 1:58 pm
I followed the instructions. Fortunately they were very simple! And I only have the one QCAD version.
  • Deleted the app.
  • Opened the DMG for my macOS.
  • Dragged the icon to the Applications Folder
The interface is still laggy. I've attached the file I'm working on in case there is something in it that can pinpoint the problem.
Anonymous Slide.dxf
(132.7 KiB) Downloaded 46 times
Bob
Bob Rockefeller
Midway, GA, USA
Post by CVH » Thu Feb 20, 2020 2:15 pm
No lag what whatsoever with the file.
Post by CVH » Thu Feb 20, 2020 2:16 pm
Did you removed the ini file?
BobRockefeller
Post by BobRockefeller » Thu Feb 20, 2020 2:17 pm
No. Where is the ini file (macOS).
Bob
Bob Rockefeller
Midway, GA, USA
Post by CVH » Thu Feb 20, 2020 2:22 pm
BobRockefeller
Post by BobRockefeller » Thu Feb 20, 2020 2:44 pm
That fixed it.
And after some experimentation, it seems as if the "problem" is switching on "Use full resolution for Retina display."
2020-02-20 at 8.42 AM.jpg (265.76 KiB) Viewed 1322 times
With that switched on, the lag returned. Bug? Or inherent limitation?
Bob
Bob Rockefeller
Midway, GA, USA
Post by andrew » Mon Feb 24, 2020 11:02 am
Using the full retina resolution will be slower by nature than using the normal resolution (QCAD has to compute / render four times as many pixels).
BobRockefeller
Post by BobRockefeller » Mon Feb 24, 2020 1:22 pm
I understand that. But I have other vector-based applications that do not slow down, or if they do, not to the point of noticeable interface lag.
I thought the days of lines at an angle rendering with jagged steps were over for modern, powerful computers such as the iMac Pro.
Are there plans to upgrade the underlying rendering engine to solve this? More and more computers, and almost all Macs, have high-resolution displays and those computers are especially prevalent in CADD.
Bob
Bob Rockefeller
Midway, GA, USA
Post by andrew » Mon Feb 24, 2020 1:31 pm
Unfortunately, we have to rely on underlying toolkits for the rendering. If you're not happy with the performance or rendering quality of QCAD, I'm happy to offer you a full refund.
