Feet and Inches in the Property Editor
BobRockefeller
Post by BobRockefeller » Wed Mar 04, 2020 2:24 am
QCAD v3.24.2 on macOS 10.15.3
I have my drawing set up in inches and dimensions set up for Architectural (3' - 4"). But I cannot figure out how to get the dimensions displayed in the Property Editor to show anything other than decimal inches.
What setting have I missed?
Bob
Bob Rockefeller
Midway, GA, USA
RandallG
Re: Feet and Inches in the Property Editor
Post by RandallG » Wed Mar 04, 2020 6:04 am
Click top menu "Edit", then Drawing Preferences, then see second choice down the list called "Dimension Settings"
Post by Husky » Wed Mar 04, 2020 6:43 am
I think that is not intended behavior. I compared the Property Editor display with the dim setting "Fractional" which works just fine ...
Please file a bugreport below: https://www.qcad.org/bugtracker
Post by andrew » Wed Mar 04, 2020 8:42 am
Currently, the property editor only supports decimal and fractional display of values.
The problem with the architectural notation is the ambiguity of the hyphen (-). QCAD supports mathematical expressions in all its input fields where values are expected. 3' - 4" could mean 3' and 4" or 3' minus 4".
One way to work around this could be to display (and input) values in the property editor as 3'4" instead. Or for example 4'10 1/4". We could use some input from users of this unit system to decide a way forward.
BobRockefeller
Post by BobRockefeller » Wed Mar 04, 2020 1:47 pm
Would a double-space between the feet and inches values work for others? So we might have 1' 3 ½".
For extra credit, if the user entered a double space, the display could read 1' – 3 ½"; single spaces but using the En Dash character.
Bob
Bob Rockefeller
Midway, GA, USA
Post by Husky » Wed Mar 04, 2020 8:59 pm
I think 3'4" or 4'10 1/4" is unambiguously to read. An input in this style would be easy too. Would work for me just fine!
I see why you are suggesting this style but I think that isn't practical. Uncommon input styles will lead to mistakes and unexpected results.
No space or one space is something what you can figure out by yourself - without knowing it you will find the double-space solution only by accident ...
BobRockefeller
Post by BobRockefeller » Thu Mar 05, 2020 1:52 am
I''d be happy with one space, then.
Bob
Bob Rockefeller
Midway, GA, USA
Post by andrew » Fri Mar 06, 2020 9:57 am
This has been implemented to the next (snapshot) release.
BobRockefeller
Post by BobRockefeller » Fri Mar 06, 2020 1:30 pm
Nice! I'm off to hunt the snapshot release download page.
Bob
Bob Rockefeller
Midway, GA, USA
