[SOLVED] Text with Clip to Rectangle
jby601
Post by jby601 » Mon Mar 16, 2020 5:07 pm
Linux Mint 19.2 Cinnamon, QCAD Pro 3.24.2.0
'Clip to Rectangle' decomposes the letters of text into their constituent segments.
To reproduce: enter text (I used Deja Vu Sans). Modify > Clip to Rectangle. Draw a box around the text. Letters are decomposed and can no longer be edited as text.
Re: Text with Clip to Rectangle
Post by CVH » Mon Mar 16, 2020 5:53 pm
Confirmed.
For 'Clip to Rectangle' to work the entities are exploded before clipping.
Furthermore no font has 'clipped' Glyphs.
QCADpro 3.24.3.0 / win7pro 32 bit / 4GB / 1e generation i7 2.6Ghz / HDD GeForce GT 520
Post by Husky » Mon Mar 16, 2020 5:56 pm
Yes, this tool needs to explode the entities before it can exercises the clip.
Common practice is to have such text on a separate layer. Lock this layer or toggle it to invisible and your text stays untouched ...
jby601
Re: [SOLVED] Text with Clip to Rectangle
Post by jby601 » Tue Mar 17, 2020 9:17 am
Thank you @CVH and @Husky.
