Blurry Menu Items
ryancousins
Blurry Menu Items
Post by ryancousins » Mon Apr 27, 2020 10:12 pm
I've noticed that some of the items in my menu bar drop-downs seem a little blurry. They look like they're supposed to be bold but instead appear to have a slight shadow effect and it makes them a little funny to look at. It only does this when using the dark theme. I'm not sure if this is due to some setting on my computer, though I haven't changed the system fonts or changed any visual settings away from Win 10 defaults.
I have attached a screenshot.
I'm running Windows 10 and QCAD 3.24.3.0
Re: Blurry Menu Items
Post by Husky » Mon Apr 27, 2020 10:42 pm
The menu items are selection sensitive. The menu entry intensity will change regarding to the selection status ...
ryancousins
Post by ryancousins » Mon Apr 27, 2020 11:04 pm
My issue is not with the fact that some of them are highlighted, but simply with the manner in which they are. It just looks a little blurry and I didn't know if that was normal.
