Layers and Blocks
Rantanplan7
Layers and Blocks
Post by Rantanplan7 » Tue May 05, 2020 1:01 pm
Hi everyone,
I have the problem that I want to move a block to a layer. I thought this is easy, so I selected the block, went to properties and changed the layer.
Unfortunately the block parts have been on different layers when I created that block.
QCAD cannot move a block to a single layer (in case the single parts are on different layers)?
Is there any function to get a block on one layer - instead of using the explode function several times to get back to the single pieces and then to move this mess to a layer?
Unfortunately this block is a combination of other blocks and I would not like to destroy everything into bits and pieces.
Best Regards
Sven
QCAD 3.24.3 / Windows 10 Professional 64-bit / 8 GB RAM, i5 [email protected], SSD
(former Autosketch 10 user)
Re: Layers and Blocks
Post by Husky » Tue May 05, 2020 7:37 pm
Yes you can move a block to an other layer.
Sure but the question is what is the final goal. A lot depend on how the block is prepared for that task. Can you attache an example dxf which shows what you try to accomplish?
