Layer issue - Paste Along Entity
Panchdara
Senior Member
Post by Panchdara » Mon Oct 26, 2020 8:28 am
I have Layer1 and Layer2
Draw a path on layer1.
Draw a small circle on Layer1.
Copy small circle (that's on Layer1).
Select Layer2.
Edit/Paste Along Entity. (Select however many you wish, say 10). I used Include end points.
The circles are drawn. HOWEVER, they are on Layer1, not Layer2...
Makes sense?
3.25.2.1
Best
QCAD 3.25.2.4 / Windows 10 2004 x86_64
Re: Layer issue - Paste Along Entity
Post by CVH » Mon Oct 26, 2020 8:52 am
Yes makes sense.
You copy an entity that exist on layer1.
The copies have the same layer property as the source. :wink:
PE doesn't have the same options as eg. PS to:
- use the current layer
- overwrite existing layers
- overwrite existing blocks
What troubles me more is that any individual hatch segment is a valid target .... :shock:
A hatch should be considered as a single complex entity not allowing certain actions. :roll:
Panchdara
Senior Member
Post by Panchdara » Mon Oct 26, 2020 9:06 am
Yeah, now the bulb filament is glowing. I was "assuming" that the pasted entity was going to take the layer property of the path. It makes sense to me now. I do appreciate your patience.
Regarding Hatches. Perhaps a suggestion to have option of an "ungrouped" hatch or a "block" hatch? Also, I'd like an option to change the hatch offset to an optional user defined origin.
Thanks again CVH.
Best
Post by CVH » Mon Oct 26, 2020 9:28 am
It's rather off-topic ...
"ungrouped" hatch
That is a hatch exploded to its segments. :wink:
That is the specific hatch property 'Origin'. :wink:
One can alter that for all installed patterns ...
... but not for orphans that come with the drawing.
"block" hatch
That is already the case for most actions. :roll:
Post by Husky » Mon Oct 26, 2020 7:19 pm
A feature request was filed months ago below:
https://www.qcad.org/bugtracker/index.p ... sk_id=2087
