				Odd circle diameter
				Posted: Mon Nov 23, 2020 8:47 am
				by CVH
				Continued from this topic:
viewtopic.php?f=33&t=7818
@ Andrew,
What double value in a dxf file (textual) results in:
-2147483648' 8988465674311578476003883458326967976270757867609612092806662678859711890369052157063584584531181568"
= plain copy off the Radius in the Property Editor, handle 0x904
Can't find any circle entry in the dxf-file that comes even close.
- 8.988465674311578E+99 (= CIRCLE 904)
1.25
1.75
0.1250000000000001
0.1250000000000001
0.1249999999999997
0.1249999999999997
0.0750000000000002
0.075
0.0750000000000002
0.075
2.025
				Re: Odd circle diameter
				Posted: Mon Nov 23, 2020 11:22 am
				QCAD cannot handle that value correctly (overflow).
				Posted: Mon Nov 23, 2020 11:50 am
				by CVH
				So, instead of NAN or Infinite or Undefined:
- It displays 110 fictive digits.
- With a wrong sign
- While Number.MAX_VALUE is known.
=1.7976931348623157e+308
Please direct me to that piece of code ... so I can utterly avoid it.
				Posted: Mon Nov 23, 2020 11:53 am
				The value is neither NaN (not a number), Infinite nor Undefined. The digits are not fictive. It's the closest value a computer can represent in memory. But I guess you know all that...
				Posted: Mon Nov 23, 2020 4:36 pm
				by CVH
				No, sorry,
I am not aware of that
-214748364' 89884656...."
is the closest value to
+8.988465674311578e+99 inch
nextUp = +8.98846567431158e+99 inch
nextDown = +8.988465674311577e+99 inch
Both are positive numbers !
Reversed we get twice the input back:
Both are still positive numbers !
This stores in memory as: 01010100 10110000 01110000 00011011 11010101 00100111 10110100 10010111
And is nowhere near the binary limit.
The first bit = 0 => positive !
The most accurate decimal notation without exponent:
+8988465674311578476003883458326967976270757867609612092806662678859711890369052157063584584531181568
Also positive and equal to the inch fraction that the Property Editor showed us.
Converting inches to feet one divides by 12.
I don't expect to get an 'overflow' from such division.
A positive number divided by 12 remains positive : +7.490388061926315e+98 feet
Again positive !
Code in a script doesn't has any problem with that. It is nowhere near the binary limit.
+749038806192631539666990288193913998022563155634134341067221889904975990864087679755298715377598464
Substracting full feets times 12 in inches from the +8.988e99 inches we get zero
Simply because 1ULP = 1.942668892225729e+84 and the remaining inches would be less as 12e0
In other words, the remainder is smaller than the accuracy.
So, yes:
Minus 214748364' 89884656...." is fully fictional, the number should start with 7.49038....
Certainly not negative.
And no, I don not know that all, I am just guessing.
				Posted: Tue Nov 24, 2020 8:01 am
				The conversion to feet / inches goes wrong (overflow when converting to inch for the feet part). The value behind the conversion is correct. Negative values are typical for overflows. There's not an awful lot a software can do when these kinds of limits are reached. The value in the file is clearly not intended. I'll have to leave it at that.
				Posted: Tue Nov 24, 2020 9:07 am
				by CVH
				andrew wrote: ↑Tue Nov 24, 2020 8:01 am
Catch them of before they even occur.
Math core of T2H is at least 6 months unchanged.
Catching off math errors is busy and very hard. Over 80 parameters.
Testing it for, and passed, reasonably limits is only half ready.
If I ever get that far, live is catching up on me.
Already dropped the endeavors for entity documentation, macro's, pocket milling, V-carving under QCAD.
I know, the questions were:
What value results in ...
And
Where does this flaw occur in the code.
A bit similar as: Why doesn't QCAD format proper numbers with LZ, TZs or better as 1e-12.
Found out all that myself by trial and error. Solved those.
I am hitting the 1ULP every day.
As Administrator, you may delete all these post.
I have a bad time and I can't handle to be attacked on simple, and straightforward things.
