Hello good people of the forum,
Long time user of the QCAD Pro version, when I open an old "3.26.0.0 qcad" design in "3.6.4.0 qcad" (fresh windows 10 install ssd blablablah) all my text zones are squeezed like "wraped" instead of nice and cleanly spread ...
So if anyone as an explanation or a solution, it will be of a tremendous help.
Xavier.
[solved] Display compatibility between versions ?
- Yeeeeah _alright !!.PNG (19.47 KiB) Viewed 3640 times
- boooo_wrong !!.png (11.85 KiB) Viewed 3640 times
Re: Display compatibility between versions ?
Please select all your texts and change the width attribute to 0 (that is zero).
If you cannot fix the problem, please do attach your drawing file, thanks.
Hello andrew,
Where can I find such width attribute ?
Andrew ... You tha MAN !!
Many Thanks for your quickness and precision !!
