[solved] Pdf export
rhkitchenandbath
[solved] Pdf export
Post by rhkitchenandbath » Wed Apr 14, 2021 1:22 am
I have MacOs Big Sur V 11.2.3, and i am using Qcad Pro V 3.25.2.0
I have used Qcad for windows for 12 years without any problems. Just purchased a new Qcad for Mac to use it on my new Mac.
I created a floor plan document and wanted to export it to Pdf format. Every time I tried to do that I get a pdf document that is hundreds or thousands of pages instead of one single page.
I suspect that the document is being created with scale 1:1 and it is exporting to pdf with the actual size.
I tried to modify the scale without success.
What am I doing wrong?
Sorry I did not attach a copy of the file. I am posting on my ipad and could not access the file in icloud.
Any help is appreciated.
Re: Pdf export
Post by andrew » Wed Apr 14, 2021 9:10 am
Please attach your drawing file when you're back at your desktop computer, thanks.
rhkitchenandbath
Re: Pdf export
Post by rhkitchenandbath » Thu Apr 15, 2021 7:31 pm
Here is the file I am having trouble with. Thank you
~kitchen floor plan.dxf
(389.35 KiB) Downloaded 325 times
Re: Pdf export
Post by andrew » Thu Apr 15, 2021 7:39 pm
The drawing is configured to print on 26 x 26 pages:
Screenshot 2021-04-15 at 20.36.51.png (80.84 KiB) Viewed 4595 times
You can change that to one single page under Edit > Drawing Preferences > Printing > Multi Pages.
You also might want to adjust the print margins.
And then auto fit the drawing using the appropriate button in the options toolbar:
Screenshot 2021-04-15 at 20.38.22.png (42.73 KiB) Viewed 4595 times
rhkitchenandbath
Re: Pdf export
Post by rhkitchenandbath » Sun Apr 18, 2021 10:38 pm
Thanks Andrew. That solved the printing issue.
Now I am having another issue with the same file. Every time I edit the file and click the “save” button it opens a new “save as” window instead and it tells me that the file already exists and if I want to replace it.
Is this supposed to happen every time I edit the file and want to save the changes made to the same file.?
Re: Pdf export
Post by andrew » Mon Apr 19, 2021 6:58 am
Please post any new, unrelated questions you might have to a new topic, thanks.
