darktheme
graziano
darktheme
Post by graziano » Thu Apr 22, 2021 9:34 am
hello everyone, with the new version of qcad Version: 3.26.2.0 (3.26.2) on macOS 10.13.6
I have dark theme display issues.
As you can see from the attached images the icons are black on a dark background and are hard to distinguish.
In addition, the option to choose themes has disappeared from the menu of preferences.
does anyone have the same problem or know how to fix it ??
bye
g
Schermata 2021-04-22 alle 10.20.05.png (64.9 KiB) Viewed 4855 times
Schermata 2021-04-22 alle 10.20.51.png (230.59 KiB) Viewed 4855 times
Re: darktheme
Post by andrew » Thu Apr 22, 2021 9:35 am
Please reset your QCAD configuration:
graziano
Re: darktheme
Post by graziano » Thu Apr 22, 2021 10:04 am
Great.. thanks
g
ryancousins
Re: darktheme
Post by ryancousins » Thu Apr 22, 2021 11:52 am
Andrew,
Thank you for the tip. I also reset my config on my Mac and noticed that the theme option was still missing from app preferences. Was the reset supposed to restore the theme option? It did resolve some of the issues from this discussion https://qcad.org/rsforum/viewtopic.php?f=8&t=8383 so that is good news. Is it a situation where the QCAD dark theme will no longer work properly on MacOS? I prefer not to use the MacOS system dark theme because I like everything besides QCAD to be the normal light colors.
Re: darktheme
Post by andrew » Thu Apr 22, 2021 12:26 pm
Themes were removed from QCAD for macOS as there are various problems with them on macOS.
On macOS, the operating system handles dark mode / light mode and also switches apps between modes. It's possible to keep certain apps in light mode when dark mode is on, but I'm not aware of an easy way to keep only one app dark in light mode.
I've seen hints on the Internet of people essentially running dark mode but forcing all but one app to use light mode instead.
ryancousins
Re: darktheme
Post by ryancousins » Thu Apr 22, 2021 12:36 pm
Thank you for the clarification and the link Andrew. I will investigate!
