Is it possible to preset Library block sizes before inserting
MarkMcC
Post by MarkMcC » Thu Apr 29, 2021 7:57 am
Is it possible to preset Library block sizes, 'before' inserting ?
When I insert library blocks, they are so small I loose them on the page !
Any thoughts ?
Thanks,
Operating System: Kubuntu 20.10
KDE Plasma Version: 5.19.5
KDE Frameworks Version: 5.74.0
Qt Version: 5.14.2
Kernel Version: 5.8.0-50-generic
OS Type: 64-bit
Processors: 2 × AMD A4-4000 APU with Radeon(tm) HD Graphics
Memory: 10.9 GiB of RAM
Graphics Processor: Radeon RX 580 Series
Version:
3.26.2.0 (3.26.2)
Internet:
QCAD.org
Build Date:
Apr 13 2021
Revision:
57092ea
Qt Version:
5.8.0
Architecture:
x86_64
Compiler:
gcc 4.8.1
Re: Is it possible to preset Library block sizes before inserting
Post by CVH » Thu Apr 29, 2021 8:54 am
Yes ... Look at your Options Toolbar.
Always do. :wink:
MarkMcC
Post by MarkMcC » Thu Apr 29, 2021 11:14 am
For some odd reason when I try that scaling method from toolbar, it makes no difference !
Thanks,
Post by CVH » Thu Apr 29, 2021 12:05 pm
Most common library items are simple dxf files.
The idea is that you choose a library item, hit the insert button, set options and then point where you want it in your drawing.
Important:
From the moment the item is inserted, it has no relation with the library item anymore.
For those that are inserted as a block one can also change the individual block reference scale later on.
Or one can scale the block entities themselves in edit mode.
But normally you don't need to do this at all.
If anything fails, then provide more information:
- Library item (If custom the item file itself)
- Scale
- dxf with item inserted
