gibberish, Garbled, when open a cad dwg file, can't show correcrt "Traditional Chinese" in TXT.
thomas0316
Post by thomas0316 » Wed Jun 02, 2021 3:23 am
When I open a dwg file from autocad format with "traditional chinese" txt. It shows gibberish.
How to do then I can get the correct content.
I attached a picture, help some can help me.
gibberish is like this:
¹Ï¸¹: T20
§÷®Æ: 6061-T5
³B²z: ¶§·¥­ì¦â
¼Æ¶q: 1 pcs
140330-TCR.dwg
(964.48 KiB) Downloaded 315 times
Re: gibberish, Garbled, when open a cad dwg file, can't show correcrt "Traditional Chinese" in TXT.
Post by Husky » Wed Jun 02, 2021 3:54 am
Would this be considered as a correct displayed text?
Post by andrew » Wed Jun 02, 2021 6:57 am
Seems to load fine here:
Screenshot 2021-06-02 at 07.59.18.png (131.07 KiB) Viewed 6586 times
For all support requests, please:
- Indicate the operating system you are using and the version thereof (e.g. Windows 10 32bit, Windows 8.1 64bit, Ubuntu 14.2 64bit, macOS 10.12, etc.)
- Indicate the exact version of QCAD you are using (see "Help" > "About" or "QCAD" > "About QCAD" or indicate the name of the file you have downloaded and installed)
- Indicate the QCAD Edition you are using (QCAD Professional, QCAD Trial-Version, QCAD Community Edition)
Please be as specific as possible in describing your problem, so we can help you efficiently, thanks.
petevick
Post by petevick » Wed Jun 02, 2021 4:03 pm
The text in the drawing uses a font called Standard, I guess that if you don't have that font available to Qcad you'll get gibberish
Pete Vickerstaff
Linux Mint 21.2 Cinnamon, Qcad Pro 3.29.6
thomas0316
Post by thomas0316 » Mon Jun 07, 2021 8:13 am
Yes, this is a correct displayed text.
But, how to do this?
Post by andrew » Mon Jun 07, 2021 8:16 am
thomas0316:
thomas0316
Post by thomas0316 » Mon Jun 07, 2021 9:10 am
Dear Andrew,
OS: Windows 10
QCAD Professional Trial
Version: 3.26.1.0 (3.26.1)
Internet: QCAD.org
Build Date: Mar 8 2021
Revision: eec8166
Qt Version: 5.13.2
Architecture:x86_64
Compiler: MSVC++ 14.0 (2015)
I use the trial version, if this problem be solved, i will use qcad pro version.
Post by andrew » Mon Jun 07, 2021 9:21 am
Please update to QCAD 3.26.4.
Please make sure you have the drawing font(s) installed used by your drawing, for example PMingLiU which is available from:
https://www.wfonts.com/font/pmingliu
thomas0316
Post by thomas0316 » Tue Jun 08, 2021 4:50 pm
I solved previous file. But, I met the same issue with new file. Please help me to solve, thanks in advance.
QCAD Professional
OS: winsows 10
Version: 3.26.4.0 (3.26.4)
Internet: QCAD.org
Build Date: Jun 4 2021
Revision: 0bb4334
Qt Version: 5.13.2
Architecture: x86_64
無機房10人(VAG)(CO900).dwg
(508.04 KiB) Downloaded 303 times
Post by andrew » Tue Jun 08, 2021 4:56 pm
The solution is the same: substitute fonts with a limited range of glyphs with a font that contains these glyphs.
For this file, substitute "romand" with for example "Arial Unicode MS" or another Unicode font.
