[solved] Symbols instead of numbers?
smcintire
Post by smcintire » Tue Jun 08, 2021 10:02 pm
I am trying to use the measuring tool, but instead of having measurement numbers I have # and a couple of circles? I am using windows 10 QCAD Ver# 3.26.4.0. Any help would be appreciated.
Drawing for firewall.dxf
(103.07 KiB) Downloaded 268 times
Re: Symbols instead of numbers?
Post by Husky » Tue Jun 08, 2021 10:11 pm
...I have # and a couple of circles?
Your actual drawing has no font for the measurements. Please change the Dimension Label Font to Standard or which ever font you like to use for dimensioning.
Menu / Edit / Drawing Preferences:
smcintire
Post by smcintire » Tue Jun 08, 2021 11:24 pm
Thank you! That fixed the issue.
