display issue, when using bitmap (solved)
bambuko
Senior Member
Post by bambuko » Sat Jul 03, 2021 3:13 pm
I have a bitmap inserted into QCAD file with some peculiar display behaviour.
I have some red lines and circles, plus green dimensions, seemingly displaying properly (image is sent to the back),
but when I hoover mouse over the image:
the lines and dimensions dissapear when the mouse is over bitmap :oops: only to appear again when the cursor is away from the bitmap.
Is this normal behaviour, or am I doing something wrong?
QCAD version: 3.26.4.0
Qt version: 5.14.2
Compiler version: gcc 5.4.0
Build date: Jun  4 2021
Revision: 0bb4334f11f4340e470c4135ae61c076a98f919f
I am using it on either on:
elementary OS or Windows 10 Pro
later edit:
the only way to somewhat mitigate the issue, is to introduce "fade" to the bitmap.
So it is OK for now, but would prefer if possible? to use bitmap without fade.
QCad Pro
Linux MX-21.3 "Wildflower"
Re: display issue, when using bitmap
Post by Husky » Sat Jul 03, 2021 7:07 pm
Put the bitmap on a dedicated layer, send it to the back and lock this bitmap layer. Try it and see if that will work in your favor ...
bambuko
Senior Member
Post by bambuko » Sat Jul 03, 2021 8:31 pm
Put the bitmap on a dedicated layer, etc ...
Thank you,
That's exactly what I did (with the exception of locking the layer)
I will try locking and report back whether it makes any difference.
QCad Pro
bambuko
Senior Member
Post by bambuko » Sun Jul 04, 2021 8:56 am
I can confirm, that locking the layer does indeed solve the problem.
Thank you!
QCad Pro
