Line length confusion [Solved - sorta]
Panchdara
Post by Panchdara » Thu Jul 15, 2021 11:46 am
Good day.
I am having some difficulty in understanding lengths of entities/lines. I attach a video and a .dxf file.
Top Original is based on first drawing a polyline rectangle (not shown) and then breaking up bits and then adding line segments. This is a wierd answer for line length.
Middle is based on an exploded version of the Top Original. I think the line lengths are in fact correct.
Bottom COPY Of Original is exactly that, a Ctrl-C/Ctrl-V of the Top Original. Wierd how Property of length asks to "Show" (unlike the other 2) and seems to give a wierd answer too, but NOT same as the Top Original.
Am I doing somethig wrong???
Thanks and all the best
QCAD-LineLengths.wmv
(5.26 MiB) Downloaded 335 times
QCAD-LineLengths.dxf
(105.2 KiB) Downloaded 338 times
Oh, and also, why is Text in BLUE Layer 3 showing RED? I originally wrote text in Layer 2 (Red layer) then moved to Layer 3. Other entities change colour (as is By Layer), but this text retains original colour.???
Windows 10
Re: Line length confusion
Post by CVH » Thu Jul 15, 2021 12:50 pm
Win7 QCAD 3.26.2.0
That is by App.Prefs. See Widgets .. Property Editor .. Show all properties
Even weirder that in my case the Top case asks for "Show" :?: :!: :shock:
In the case without "Show", the 73.32968 is the length of the second pick, a line entity.
After the third pick it sums only the line entities :!: :shock:
Considered buggy. You could file a report about that.
A solution would be setting the preferences to show all.
The text is red because of the Rich text color switch "\C". aka "\C1;\H16;Original"
Also,
Remark the double horizontal line Left-High.
Top case and Botom case have one polyline.
If this is bend material, then inner angle and outer bend radius would differ.
Post by Husky » Thu Jul 15, 2021 7:09 pm
Well, I would try it with a drawing that doesn't contains duplicated entities. Maybe the result is then less confusing .... :shock:
Panchdara
Post by Panchdara » Thu Jul 15, 2021 7:44 pm
Many thanks.
Please see attached video.
Perhaps my workflow is awkward, but the only typing were the numbers for offset and for the initial 250x8 rectangle (polyline). I am not convinced here.
QCAD-LineLengths1.wmv
(8.04 MiB) Downloaded 423 times
Windows 10
Post by CVH » Thu Jul 15, 2021 8:37 pm
I asume that in your second video it is again only the sum of the line entities, disregarding the polyline left-high.
With the preference set to 'show all', summing appears to be flawless.
The same buggy nature, and I can replicate it with other designs too. :wink:
@ Husky,
With the dwg file:
It is quite easy to:
- Remove the duplicate line 3 times.
- Clear the 'show all' preference & reboot.
- Verify the buggy nature.
Post by Husky » Thu Jul 15, 2021 9:18 pm
So far I can't reproduce that:
What exactly means this in un-encrypted language?
Panchdara
Post by Panchdara » Thu Jul 15, 2021 9:24 pm
Okay. I think there is an "undocumented characteristic" here.
Husky mentioned duplicate entries - Not sure where they mysteriously popped up.
CVH. Under Application Preferences, the Property Editor, the "Always show all properties..." seems to have solved this issue (an application restart is required but not prompted for or mentioned). Thank you. I have since looked (albeit not exhaustively) for this setting description... not found it yet (sorta like the TAB key from the Command Line? Hotkeys are not easily found online but I did find it in an old 2006 copy of the user manual (v2.x?)- and that was a find!)
Thanks CVH... I'll edit to say solved, but not a clean solution.
Best regards
Posted whilst Husky replying. Thanks Husky, that did solve that particular issue... not sure why though.
Windows 10
Re: Line length confusion [Solved - sorta]
Post by CVH » Fri Jul 16, 2021 6:11 am
Really?! There is nothing encrypted to it!
App.Prefs Show All.png (49.3 KiB) Viewed 5984 times
not Show All.png (21.49 KiB) Viewed 5984 times
With the preference cleared = default.
(Introduced Jun 18, 2018 : https://github.com/qcad/qcad/commit/3a8 ... 6e491d63d4)
(See Changelog: 3.21.0 (2018/06/26) aka "Add support for requestible (slow) properties")
And with a mixed selection including 'slow' properties.
  • Might display "Show"
    OR
    Might sum the length of the two line entities only : 000 + 73.32968 + 98.246095 = 171.575775
(Sorry about the lack of decimal positions, I have asked you personally HowTo)
not Show All_2.png (22.83 KiB) Viewed 5984 times
Not being consistent with Panchdara Top-Bottom in his first video is already buggy.
Not displaying "Show" consistently with 'slow' properties is also buggy.
===== Temporary Solution =====
With the preference set, what always requires a Reboot! (Not always prompted for!)
Sums all the lengths: 166.246095 + 73.32968 + 98.246095 = 337.82187
'Slower' but flawless considering the 6 or 8 decimal digits rounding.
Show All.png (22.3 KiB) Viewed 5984 times
Was being so detailed, down to pictures and references, really necessary?
No regards,
