Hi there!
I'm trying to generate maptiles from DXF files and everething seems fine except one file.
Service info: Win 10 Professional, QCAD v 3.26.4.
Generating goes in 2 steps:
1 - converting dxf coordinate system from EPSG:31467 to EPSG:3857
2 - generating map tiles from converted DXF-file.
Convertion runs dwgmapconvert.bat file with more arguments
- [logFileName] -crs-in=EPSG:31467 -crs-out=EPSG:3857 -f -o[outputFileName] -[sourceFileName]
Generating runs dwg2maptiles.bat file with more arguments
-[fileName] -web-mercator -skip-empty -b transparent -f -o [outputDirName] -z 17-17 -[logFileName]
In good case I'm getting all needed tiles, but with one file I'm gettint just a small part of tiles. I suppose that problem is in source DXF-file, but I have no idea about what's wrong with it.
I attached this wrong file and also attached log-files for converting and generating tiles.
Can you give me a direction to look for source of this problem?
Wrong map tiles generation
- 60f51d423f710936a29a75b7.dxf
- Bad DXF file
- (879.55 KiB) Downloaded 269 times
- dxf_to_mt_60f51d423f710936a29a75b7_z_17.dxf.log.log
- Generating log file
- (471 Bytes) Downloaded 287 times
- dwgmapconvert_DXF_to_WGS84_292_60f51d423f710936a29a75b7.log
- Converting log file
- (285 Bytes) Downloaded 276 times
Re: Wrong map tiles generation
The maptile output with the file you have attached, using the two commands as indicated above:
https://qcad.org/res/tmpmap (only level 17)
This looks fine here as far as I can tell.
Do you run the tools in a command line prompt or from an application / script / web service / etc?
In the latter case, please rerun in a command line prompt to rule out any issues with running the processes from your application / script.
Hi andrew. Thanks for answering.
My code executes batch file. I can not attach it to this post. This is the content of this file:
qcadcmd.com -allow-multiple-instances -autostart scripts\Pro\Tools\DwgMapConvert\DwgMapConvert.js -crs-in=EPSG:31467 -crs-out=EPSG:3857 -f -o "output.dxf" "60f51d423f710936a29a75b7.dxf"
qcadcmd.com -allow-multiple-instances -autostart scripts\Pro\Tools\Dwg2MapTiles\Dwg2MapTiles.js "d:\QCAD\output\outputLog.log" -web-mercator -skip-empty -z 18-18 -f -b transparent -o "d:\QCAD\output" "output.dxf"
Again, please do try to rerun these commands manually from a command line prompt (cmd.exe) to rule out any issues with running the processes from your application.
A common problem is that a child process is forced to terminate prematurely if the calling application does not wait for its child processes to terminate. Please note that these are issues unrelated to QCAD or the QCAD Command Line Tools but related to process management and programming.
In a fact this is just sample .bat-file to reproduce my issue. I start it manually. Console output in my case looks like on the attached image.
As you can see only 2 tiles were generated fo 18 zoom level after execution. This is too small count for this DXF.
- Console ouput
- 2021-07-19_11-41-03.png (37.83 KiB) Viewed 4991 times
Just new information. I've found that this DXF uses MText elements. All DXF without it have no problem with tiles generation. Can it be the reason?
Thanks for the details. It's a problem with the spatial index that ships with Windows packages. We have released a snapshot release (3.26.4.5) today which comes with a different spatial index module that should fix the problem. The update is available from your download link under "Snapshots".
