Export to pdf
Export to pdf
When I export to pdf the files get rather big. Can I somewhere set the size?
Re: Export to pdf
No but if you need to reduce the file size you can use a Third Party pdf print driver. Please keep in mind that reducing the pdf size means also reducing the pdf quality ...
