The right side of the attached drawing is mirrored from the left and shows a curious displacement of some small lines.
The original from the web was full of duplicate lines (about 6000...) - which I removed - and I replaced all curves with circle segments to reduce the complexity.
Still I don't manage to make mirroring correct. It seems to happen with short lines near curves.
Rob
Version:
3.26.4.0 (3.26.4)
Internet:
QCAD.org
Build Date:
Jun 4 2021
Revision:
0bb4334
Qt Version:
5.14.2
Architecture:
x86_64
Compiler:
gcc 5.4.0
[Solved] Mirror problem
- mirror-problem.dxf
- (1.42 MiB) Downloaded 241 times
Linux Mint 20 , qcadcam-3.24.3.10-pro-linux-x86_64
Re: Mirror problem
Your drawing contains Z coordinates (3D), please flatten with Misc > Modify > Flatten Drawing to 2D
Re: [Solved] Mirror problem
Thanks Andrew,
That solved it.
Rob
That solved it.
Rob
Hi Rob,
Have a closer look at (344.83, 115.9929) or entity with handle: 0x780a
Zoom in deep.
There are more of such and there are (near) Null-length entities too.
Zoom in deep.
Hi CVH,
Thanks. Shows that any download from the web needs some checking...
Anyway, I deleted it after redrawing by hand. Looks tidy now.
Robert
Robert
