Hello guys,
How can i do this in new versio of qCad?
Older version this was no problem, but how now?
And same to when 0-layer is locked, then I can't unlock sublayer? Why or how?
Thanks for everybody
The sublayer visible when 0-layer is unvisible
Re: The sublayer visible when 0-layer is unvisible
Uncheck the preference:
Edit > Application Preferences > Widgets > Layer List > Switching off means freeze
Qt Version: 5.13.2
Operating system: Win 10 Pro / 64bit.
- sc settings.png (21.35 KiB) Viewed 4700 times
- sc layers.png (30.92 KiB) Viewed 4700 times
- sc file.png (22.09 KiB) Viewed 4700 times
Yesss, problem found
When you click the "hide all" button, you will not be able to show individual layers if the 0-layer is hidden.
But if you hide all the layers one by one, then you can make one layer visible.
The same button causes a problem locking layers that do not work properly after you press the button.
Thanks for good software, even Mercedes has programming errors
- sc problem in this button.png (35.99 KiB) Viewed 4692 times
