Qcad locked
Antonio.A
Qcad locked
Post by Antonio.A » Mon Jan 17, 2022 3:41 pm
Hello!
Environment:
OS: Windows 10 Home edition
RAM: 8 GB
Qcad 3.27.1 trial-win64
I just downloaded Qcad 3.27.1 trial-win64 to try it and, eventually, buy it but now Qcad seems to be locked and I cannot access configuration option.<br/>
Step:
  1. Install Qcad
  2. Open general settings (I cannot remember which from which menu)
  3. Inadvertently, I set GUI scale to 0.8 to reduce icons dimensions
  4. Exit and relaunch Qcad
  5. Qcad GUI is confused and not randomly resized: cannot find settings menu option
  6. quit from Qcad
  7. Uninstall Qcad
  8. Reinstall Qcad
  9. Reboot my PC
  10. Run Qcad
  11. same problems as at point 5.
  12. quit from Qcad
If GUI scale must be 1 or more, then Qcad should not allow settings lower than 1.
Then: how can I restore initial (factory) settings for Qcad?
Thank you
Qcad GUI after GUI scale set to 0.8
Re: Qcad locked
Post by andrew » Mon Jan 17, 2022 3:54 pm
