I receive dwg files with plans from an architectural office (which uses Vectorworks). These dwg files are terribly heavy to handle with Qcad.
Zooming, drawing lines, saving the file, ... is very painful).
The size of the file is however reasonable (1.7 Mo)
architectural plans :
I am used to working with dwg plans sometimes much heavier (5 - 10 Mb) and I don't encounter these problems.
Thank you for your advice to be able to work in a more "comfortable" way.
QCAD version: 3.27.1.0
Qt version: 5.14.2
OS: Linux
OS version: 20.04
[solved] dwg files heavy to handle
Re: dwg files heavy to handle
This drawing is heavenly loaded with hatch pattern. That cost QCAD a lot of time to render the drawing ...Philsourish wrote: ↑Wed Jan 19, 2022 10:53 pmThank you for your advice to be able to work in a more "comfortable" way.
Move all hatches to a new layer (Menu/Misc/Layer) and switsch that new Hatch layer to invisible. Should make it less painful to work with ...
Same story here:
https://qcad.org/rsforum/viewtopic.php? ... 193#p36193
Please also read the last two lines.
We've been seeing more hatches lately that are coded incorrectly.
https://www.ribbonsoft.com/bugtracker/i ... sk_id=2325
Re: [solved] dwg files heavy to handle
thank you very much for the advice
It works like a charm!
