There must be a mistake elsewhere when this message shows
But I'm not able to get it right
It seems it appears when I elaborate drawings whose source was a .dwg drawing that I converted into a .dxf
It doesn't show when I create new drawings directly in .dxf
Am I right----?
Help!
Marco
Error
Error
- 20220130_211103[1].jpg (5.94 MiB) Viewed 2374 times
Re: Error
It could be that the conversion from dwg to dxf failed. Why not going to open the dwg directly in your QCAD Pro version?Marco Giaccone wrote: ↑Sun Jan 30, 2022 9:26 pmIt seems it appears when I elaborate drawings whose source was a .dwg drawing that I converted into a .dxf
