QCAD version: 3.27.1.0 (3.27.1) on MacOS Monterey 12.2.1
This is a new issue (to me) and has started after I successfully created a TitleBlock with multiple attributes. This exception occurs with Save, SaveAs to .dwg format or AutoSave to .dxf format. I created a new blank drawing without TitleBlock and Save/SaveAs works as expected without exception.
In spite of the message changes to the drawing do seem to be saved at least simple changes like lines and shapes. Is there some sort of error log and if so where is it located. The drawing itself is trivial, just a frame with title text/attributes in PaperSpace and a few circles and a rectangle in ModelSpace.
My other more complicated drawings (without Layout TitleBlocks) save as expected so it seems that it is in some way related to this particular drawing???
Command: save
Exception occurred. Entity NOT saved: 3c0
Saved file: /Users/richardwilkinson/Documents/My Drawings/A4Land.dwg
Format: R27 (2013) DWG Drawing (OpenDesign) (*.dwg)
A4Land.dwg attached
- A4Land.dwg
- (20.7 KiB) Downloaded 237 times
Re: Exception occurred. Entity NOT saved: 3c0
Please avoid posting the same question 4 times - it will not speed up any response to it. I deleted the other three identical posting!
Your drawing issue: You managed to created in Paper_Space a Viewport with zero Width and zero Height - I assume by accident. That is an invalid value and will not be saved by QCAD. Delete this Viewport or change the Width / Height to something greater than zero and you can save the drawing as usual.
I think this is harsh, unnecessary and offensive considering that you don't know what happened. I'll tell you.
I created my post, navigated to and selected my .dwg file to upload and clicked submit. The response was a message "about 20 random chars.gif invalid file format" and the web page frozen for 30-40 seconds. And for the record I did not select a .gif file. Faced with a frozen page and no indication of whether my post had actually been submitted or not I could have killed my browser session (and lost the entire post) or tried to illicit a response by clicking on the page. After the long wait the next message said "you can't post this soon after your last post" but I still had not received any notification that my post had been submitted.
I speculate that some/all of my random clicks were actually "stored" or "actioned" in background but no notifications given. I further speculate that if you noted the timestamps on the multiple postings they would have all been within a few seconds, likely to have been too close together to have been manually submitted.
I had no idea that this had happened. Not me, it was the website
Ok rant over.
Thank you for identifying the issue with my drawing. You are correct in that it was not intentional to create an invalid entity. However I suggest that there is a weakness in the interface because it should not be possible to do what I appear to have done.
You have told me the solution ie. to delete/resize the offending entity but I don't know how to. I have been unable to find a way to list all my viewports, being zero height/width it is invisible? unselectable?
Strike last para. I found it!!! I did a window selection within the existing viewport and a single blue square appeared in the middle, GP showed it as a viewport with height/width zero, delete and job done.
Thank you for your help
Thanks for clarification! I owe you one ...
Great - you figured it out. To make it next time easier you can use the Selection Filter. How? You knew it is in Paper_Space, it's a Viewport and has zero height/width - that's enough information to find it with the Selection Filter ...Wilko500 wrote: ↑Tue Mar 08, 2022 11:49 pmYou have told me the solution ie. to delete/resize the offending entity but I don't know how to. I have been unable to find a way to list all my viewports, being zero height/width it is invisible? unselectable?
Agreed, casting null-entities or null-length entities should be avoided.
But that statement is not fully backed by the developer.
These are only meaningfull internally at code level.
