(Solved) Edit block in-place performance
seasdes
Senior Member
Post by seasdes » Sun Mar 27, 2022 12:24 pm
When I Edit Block In-Place it takes a few seconds before I can do any modifications. It appears that QCAD is doing some calculations in the background. The same happens when I save and exit the block. I have attached a copy of the block. The lag is more pronounced if the Block is inserted in a drawing that has some other entities.
The problem does not occur if I use the standard Block editing command.
Any ideas why this might be occurring.
BLOCK TEST.dwg
(75.09 KiB) Downloaded 226 times
seasdes
QCAD Pro V3.27.8
User since 2021
W10
Re: Edit block in-place performance
Post by andrew » Sun Mar 27, 2022 9:02 pm
Editing a block in place is essentially the same as exploding the block (while remembering what the block consisted of). This is much more involved than editing a block in the block editor as entities have to be moved, scaled and rotated into place and back again.
Post by Husky » Sun Mar 27, 2022 9:24 pm
Well, this drawing is a challenge for QCAD ... :shock:
This drawing is built with many stacked blocks - I wouldn't recommend that but it is possible to do. The real problem is that those blocks collected a lot of senseless text entities. To be exact: 833 Text entity with a text size of 0.18 mm. They are all part of blocks what means they have all to be processed ...
If you clean the drawing from those "lost" text entity's QCAD has no performance problems at all in "Edit Block in Place" mode.
BLOCK TEST_mod.dwg
(49.81 KiB) Downloaded 229 times
Would you agree? :wink:
seasdes
Senior Member
Post by seasdes » Mon Mar 28, 2022 1:32 am
Thanks Andrew and Husky.
I can see the performance improvement when the nested(stacked) blocks are exploded.
However, nested blocks are essential to my work. You refer to "senseless text entities" - How did you clean them?
seasdes
QCAD Pro V3.27.8
User since 2021
W10
Post by Husky » Mon Mar 28, 2022 2:29 am
Please use in Model_Space Zoom All. You will notice that it shows much more then the main drawing. This effect should always alarm you ... :wink:
Ok, how to fix ...
Edit block "fLOOR pLAN",
use the Selection filter to find all blocks,
explode those blocks,
use the Selection Filter to find all Text,
use Zoom All to see what is going on - the Text is scattered all over the place ...
delete the Text - done.
If you now switch back to Model_Space you will note that Zoom All shows just the main drawing - nothing else.
seasdes
Senior Member
Post by seasdes » Mon Mar 28, 2022 2:36 am
Thanks Husky
seasdes
QCAD Pro V3.27.8
User since 2021
W10
